Full Version: Small Video Window
I'm not sure if this is a Titan issue or a Simple PVR issue, but when using kodi on my laptop (win10), when I start a channel from the PVR, then hit the back button, the guide reappears and a small video windows in the lower left corner and continues to play the channel I'm on till I stop it or switch it.
However, on my Android device, when I do the same thing, the small video window doesn't appear.
I read elsewhere that maybe its a media codec/media codec (surface) setting issue..  but I tried all 3 options and none of them work correctly..
I have both mediacodec accelerators on..  If I turn them surface off and leave other one one..  kodi immediately crashes when you try to open the pvr; if you turn surface on leave the other one off..  and the video window appears, but the rest of the screen goes black and the pvr guide doesn't appear.
