Full Version: WIN64 -Nightly-since may 31 - Problem with windowed mode
Hello,
something has changed on the 64b Windows (10) nightlies with all versions since 31-May-2018.
Since then windowed fullscreen mode doesnt work properly - tested on 2 independed Win10 systems.
Setting-System-Display >> Display Mode Fullscreen AND "Use fullscreen window" = Yes
fullscreen window works, but when I press ALT+ENTER to windowed mode and again ALT+ENTER it should switch back to windowed fullscreen,
but it is fullscreen non-windowed even it still shows "Use fullscreen window" = Yes.
The problem is in non-windowed mode I don't see the volume bar overlay.
As I wrote this happens with all nightlies since may-31. It was working before...
Is it possible to fix that?
Thank you
n
