2018-06-23, 09:33
Have been using the database cleaner (https://forum.kodi.tv/showthread.php?tid=272112)
and found that I have a single entry left, but do not know how to remove it.
I used sqlite to check, and it is there:
$ sqlite3 /home/derek/.kodi/userdata/Database/MyVideos108.db
sqlite> select * from path where strpath='/';
375|/||||||||||
Guess it is not going to hurt much as I removed the other 703 unused references, but it would be nice to know how to remove it.
I tried doing a replace for the strpath, but it just ended up referencing all others using that new name.
I figure I need to find the actual entry that is using that path and remove it, but the column names of the tables don't help at all
Regards Derek
375|/||||||||||
Regards Derek
