Full Version: Vbox with Kodi Leia V18 Alpha 2 - Recordings Won't Play
I have test installations of Kodi running V17.6 & V18 Alpha 2, both running against the same library & VBox Product Number 3442 running Software Version XTI_VJ.2.59. These Kodi versions also share the same Kodi profile.
I can play recordings on V17.6 but not on V18 Alpha 2.
The kodi log entries for V17.6 are:
17:00:24.386 T:11168  NOTICE: VideoPlayer: Opening: http://192.168.1.9:55555/NetworkMedia/Ne...0%2D00.mpg
17:00:24.386 T:11168 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
17:00:24.475 T:11168   ERROR: DXVA::CProcessorHD::IsFormatSupported: Unsupported format 104 for 1.
17:00:24.475 T:11168   ERROR: DXVA::CProcessorHD::IsFormatSupported: Unsupported format 105 for 1.
17:00:24.475 T:14544  NOTICE: Creating InputStream
17:00:24.707 T:14544  NOTICE: Creating Demuxer
17:00:25.225 T:14544  NOTICE: Opening stream: 1 source: 256
17:00:25.225 T:14544  NOTICE: Creating video codec with codec id: 28
17:00:25.225 T:14544  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
17:00:25.225 T:14544  NOTICE: Creating video thread
17:00:25.225 T:14544  NOTICE: Opening stream: 0 source: 256
17:00:25.225 T:14544  NOTICE: Finding audio codec for: 86066
17:00:25.225 T:15760  NOTICE: running thread: video_thread
17:00:25.226 T:14544  NOTICE: Creating audio thread
17:00:25.226 T:14544  NOTICE: Opening stream: 2 source: 256
17:00:25.226 T:16464  NOTICE: running thread: CVideoPlayerAudio:Tonguerocess()
17:00:25.423 T:14544  NOTICE: Opening stream: 1 source: 256
17:00:25.423 T:14544  NOTICE: Creating video codec with codec id: 28
17:00:25.423 T:14544  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
17:00:25.423 T:14544  NOTICE: Opening stream: 0 source: 256
17:00:25.423 T:14544  NOTICE: Closing stream player 3
17:00:25.423 T:14544  NOTICE: Opening stream: 2 source: 256
17:00:25.429 T:15760  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1920x1080)
17:00:25.436 T:16464  NOTICE: Creating audio stream (codec id: 86066, channels: 2, sample rate: 48000, no pass-through)
17:00:25.493 T:11168  NOTICE: D3D: rendering method forced to DXVA processor
17:00:25.493 T:11168  NOTICE: DXVA::CProcessorHD::InitProcessor: Supported deinterlace methods: Blend:yes, Bob:yes, Adaptive:yes, MoComp:yes.
17:00:25.503 T:11168 WARNING: CWinRenderer::UpdateVideoFilter - chosen scaling method 1 is not supported by renderer
17:00:26.051 T:15760 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
17:00:26.352 T:15760  NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 43636
17:00:30.107 T:11168  NOTICE: CVideoPlayer::CloseFile()
For V18 Alpha 2:
6:55:12.261 T:15164  NOTICE: VideoPlayer::OpenFile: pvr://recordings/tv/active/Building%20Britain%27s%20Canals, TV%20(Channel%205%20HD), 20180619_021000, 10020.pvr
16:55:12.261 T:13332  NOTICE: Creating InputStream
16:55:12.262 T:13332   ERROR: CVideoPlayer::OpenInputStream - error opening [pvr://recordings/tv/active/Building%20Britain%27s%20Canals, TV%20(Channel%205%20HD), 20180619_021000, 10020.pvr].
The call to the recording file is completely different under V18 & appears to be pointing to the wrong location.
Keith
Yes same here, it would be nice to have this fixed.
Please file an issue here: https://github.com/kodi-pvr/pvr.vbox/issues
EDIT: which add-on version are you using? As far as I can see the official pvr.vbox add-on does not support recordings (and never did).
EDIT2: nvm, it does. ;-)
I already found the problem. Will try to come up with a fix soon.
Much appreciated, thank you.
You're a star - is there anywhere I can download the updated version now or do I have to wait for it to get changed?
(2018-06-26, 17:34)mattmarsden Wrote: [ -> ]You're a star - is there anywhere I can download the updated version now or do I have to wait for it to get changed?
If you cannot build the updated add-on yourself, you will have to wait until the fix PR got merged. Then, the fix will be included automatically in the next Kodi nightly build.
Ksooo,
Thanks for the prompt reply & the fix. I'll pick it up in the nightly shortly. It's not a priority for me at the moment 'cos it's not my production system. Just wanted to get the problem raised.
Keith
Merged, fix should make it into next Leia nightly build.
Works perfectly now thanks.
