Full Version: OSMC - VERO4K widgets refresh with Aura Skin
Hello Smile
Recently I bought a VERO4K from OSMC, and VERO4K is a box that runs 24/7 because is plugged to a wall power source.
My problem is that because it runs 24/7, the widgets don’t refresh automatically (for example Twitch widget).. sometimes it shows that ( for example: summit1g is streaming) and when I click to open he is not streaming because the widget was not refreshed..
How can I set a widget to refresh every x hours?
I hope you understand my problem !! Because my English is very bad!!
The answer might depend a bit on the exact mix of addons and skin.  The default Estuary skin, for instance, updates it's widgets every hour or so from what I can tell.  You can force an update by either doing a library update or refreshing the skin.  Both those things can be automated with a little programming knowledge, but I don't know if that would help in your case.  You might look in the skin section of this forum and see if the skin your using has a thread, and if you're using the default OSMC skin you could check on the OSMC forum:
https://discourse.osmc.tv/
(2018-06-25, 03:20)pkscout Wrote: [ -> ]The answer might depend a bit on the exact mix of addons and skin.  The default Estuary skin, for instance, updates it's widgets every hour or so from what I can tell.  You can force an update by either doing a library update or refreshing the skin.  Both those things can be automated with a little programming knowledge, but I don't know if that would help in your case.  You might look in the skin section of this forum and see if the skin your using has a thread, and if you're using the default OSMC skin you could check on the OSMC forum:
Thanks for your help Smile
I will search for a possible fix!
Have a nice day !
