(2020-05-18, 03:27)kenmoon Wrote: [ -> ] (2018-06-28, 06:03)mikeSiLVO Wrote: [ -> ]@Karellen Thanks for the info
@Maaarv Should be easy to test by downloading this file.
Overwrite that file in the skins 16x9 folder and restart kodi if already running. If all is working well then the BluRay flag should appear in both library views and fullscreen playback.
Hello
I can not download this file you linked.
I need it or if it already applied to Aeon skin , please let me know which file you update.
Thank you
I would like to have the file too! Thank you!
Hi, seems the problem still occurs. My BDMV is well scraped but all the meta tags for video and audio are not showing up.
Thanks for your help
(2020-11-01, 03:19)Marcoparigi Wrote: [ -> ]My BDMV is well scraped but all the meta tags for video and audio are not showing up.
Yes. It is broken for Bluray, DVD and ISO formats. It only works for single video files like mkv.
It is not a skin issue, but an issue with changes made to Kodi core last year.
Here is one of the PR's related to it. I have made another comment at the end.
https://github.com/xbmc/xbmc/pull/16342
Thanks a lot for your quick feedback !
Hope they change that back one day...
Have a nice day !
Cheers
(2020-11-01, 04:41)Karellen Wrote: [ -> ] (2020-11-01, 03:19)Marcoparigi Wrote: [ -> ]My BDMV is well scraped but all the meta tags for video and audio are not showing up.
Hi @
Karellen is this issue already fixed?
Cause the media flags are still not showing up with BDMV structure.
(2021-03-17, 18:32)Pienoet Wrote: [ -> ]Hi @Karellen is this issue already fixed?
No, it is not fixed yet. No developer has shown interest in it. You will need to add the details via nfo files.
