Hi all,
In the last couple of weeks, I have found that the HGTV, DIY Network, Cooking Channel and Travel Channel Addons have no content in that when you open the addons, it simply says Files, Playlists, Video Addons. Previously, they always had lots of shows to choose from which all worked.
Does anyone else have this problem?
(2018-06-26, 17:22)markelanduk Wrote: [ -> ]Hi all,
If you are running Kodi builds post June 10th.... There is a chance some plugins will experience routing issues and will require updating from the plugins author. Please contact the author and let them know about this commit:
https://github.com/xbmc/xbmc/pull/13814
I'm the author of those add-ons. They work fine for me.
If you want support, please post in the correct support thread for the add-on not working and include a full debug log.
Please do not open new threads, they are generally not seen.
Apologies for that.
Do you think it might be because I'm outside of the US? It's never been an issue before.
Just to add that I just downloaded Kodi on my PC (I also have it on another USB Type device) and tried to access the likes of HGTV with a VPN and the same thing happened i.e. it just says Files, Playlists, Video add-ons.
Correct support thread for HGTV is:
https://forum.kodi.tv/showthread.php?tid=237173
