Full Version: Flirc issues?
Picked up a flirc v1 of ebay and I'm having issues (would ask at flirc forums but they are down)
I'm trying to end up with my dish network 40.0 remote running everything. So I clear config. select kodi preset and then program in my keys from the aux on the dish remote, save config. (tried force firmware upgrade also no diff.) Everything looks great, plug it into my kodi box and nuttin?
So I have an old worn out  logitech harmony 520 (default flirc support) and it runs the flirc fine, so I take the harmony and use the "teach" function to program the dish remote with the logitech codes, all seems to go  well but the newly taught codes do not work ;-(
Any ideas, thanks..
Well changing the base remote to a NEC dvd player seems to have solved it..
