Hello,
I am experiencing a problem with the leia alpha 2 version.
It doesn't adjust anymore the refresh rate to 24hz for HD video that needs it.. And it was working fine on kodi 17.6..
I tried to white list the 24hz resolution but there is only 50hz and 60hz resolution in the listing choice... Can't neither put the kodi resolution to 24hz, same pb, not on the listing.. And still, with kodi 17 it was working so my (recent) TV support it..
I have upgraded to leia alpha 2 on my android TV box because I was experiencing some problems with some SD videos (leia has resolved them)
Anyway, would be great to have the 24hz refresh rate again... Any idea ?
Real tanks for the help,
Best Regards
hello,
Here is
the log debug. and 2 screenshots showing the
whitelist and
the refresh rate..
As said in another post, what's strange is that I can see that the 24hz resolution is found..
But nothing in the whitelist choice or in the refresh rate choice ...
extract :
Quote:20:26:11.419 T:18446744072280344864 DEBUG: CAndroidUtils: current mode: 5: [email protected]
20:26:11.420 T:18446744072280344864 DEBUG: CAndroidUtils: available mode: 1: [email protected]
20:26:11.420 T:18446744072280344864 DEBUG: CAndroidUtils: available mode: 2: [email protected]
20:26:11.421 T:18446744072280344864 DEBUG: CAndroidUtils: available mode: 3: [email protected]
20:26:11.421 T:18446744072280344864 DEBUG: CAndroidUtils: available mode: 4: [email protected]
20:26:11.421 T:18446744072280344864 DEBUG: CAndroidUtils: available mode: 5: [email protected]
20:26:11.421 T:18446744072280344864 DEBUG: CAndroidUtils: maximum/current resolution: 1920x1080
20:26:11.421 T:18446744072280344864 DEBUG: CAndroidUtils: selected resolution: 0x0
20:26:11.425 T:18446744072280344864 INFO: RetroPlayer[PROCESS]: Registering process control for Android
20:26:11.425 T:18446744072280344864 INFO: RetroPlayer[RENDER]: Registering renderer factory for OpenGLES
20:26:11.493 T:18446744072280344864 NOTICE: CAndroidUtils: window resolution: 1920x1080
20:26:11.493 T:18446744072280344864 NOTICE: CAndroidUtils: Current resolution: 1920x1080 1920x1080 @ 50.000000 - Full Screen
20:26:11.493 T:18446744072280344864 DEBUG: CAndroidUtils: ProbeResolutions: 1920x1080
20:26:11.494 T:18446744072280344864 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
20:26:11.494 T:18446744072280344864 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
20:26:11.494 T:18446744072280344864 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
20:26:11.494 T:18446744072280344864 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
20:26:11.494 T:18446744072280344864 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
20:26:11.494 T:18446744072280344864 NOTICE: Found ([email protected]) at 20, setting to RES_DESKTOP at 16
