2010-01-20, 11:29
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100
2010-01-20, 11:39
milenko79 Wrote:So, can we jaunty users install the latest svn version, even though it says it has a dependency missing?
Which is the missing dependency ?
2010-01-20, 11:51
wattazoum Wrote:Which is the missing dependency ?
Launchpad says: https://edge.launchpad.net/~team-xbmc-sv...ld/1456127
Maybe i'm not reading it correctly and it doens't matter, but that's why i'm asking
2010-01-20, 12:03
Ah, this issue happens on lpia arch. You might not need to care about it (if you don't use this arch).
2010-01-20, 12:21
Haohmaru Wrote:Thats what I get after those two commands:confused2:
xbmc@XBMCLive:~$ sudo apt-get update
snip....snip....
Reading package lists... Done
xbmc@XBMCLive:~$ sudo apt-get dist-upgrade
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Its still the original live 9.11 build from dec 24
Can you give me some advice ?
This is how i did it
change to the following in the /etc/apt/sources.list.d/xbmc.org.list
deb http://ppa.launchpad.net/team-xbmc-svn/ppa/ubuntu karmic main
deb-src http://ppa.launchpad.net/team-xbmc-svn/ppa/ubuntu karmic main
with command:
sudo pico /etc/apt/sources.list.d/xbmc.org.list
get the key for svn
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 64234534
update to latest xbmc
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install xbmc
sudo reboot
this is from the guide "How to Install XBMC-Live to My HTPC and Update to Bleeding EDGE" from newb2linux
2010-01-20, 19:16
Meteorite Wrote:This is how i did it
Code:deb http://ppa.launchpad.net/team-xbmc-svn/ppa/ubuntu karmic main
with command:
Code:sudo pico /etc/apt/sources.list.d/xbmc.org.list
get the key for svn
Code:sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 64234534
Code:sudo apt-get update
sudo reboot
thx that worked like a charm
my only problem was that I had edited the /etc/apt/sources.list and not the one you wrote
2010-01-20, 23:55
Are these are the keys I need to get the unified front-end, or would I need different keys?
2010-01-22, 04:29
Anyone having problems accessing SMB shares on 27017? As of this version, I am getting the Error 2: Share not available error when I try to browse for my shares or when I try to Add a Network Location. The only thing that has changed is I updated to the latest SVN available and now all hell has broken loose.
2010-01-22, 09:04
Installed latest SVN-build and now It won't automount my usb-hd anymore. Any ideas of what changed?
2010-01-22, 16:55
tigertailz Wrote:Installed latest SVN-build and now It won't automount my usb-hd anymore. Any ideas of what changed?I have the same problem, shutdown, restart etc. doesn't work either. So I have to stay at 9.11.
2010-01-22, 17:51
nugentgl Wrote:Anyone having problems accessing SMB shares on 27017? As of this version, I am getting the Error 2: Share not available error when I try to browse for my shares or when I try to Add a Network Location. The only thing that has changed is I updated to the latest SVN available and now all hell has broken loose.I'm not sure what the error code is, but I noticed this in the log. It's weird b/c the remote PC is on (I'm on it now) and I can play movies from that directory on the XBMC box so I don't know why it can't find it.
10:40:21 T:70130544 M:890925056 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://media%2dserver/media/Movies'
unix_err:'6e' error : 'Connection timed out'
10:40:21 T:70130544 M:890925056 ERROR: GetDirectory - Error getting smb://media-server/media/Movies/
10:40:23 T:70130544 M:890925056 NOTICE: My Videos: Scanning for video info using worker thread, operation took 00:11
10:40:23 T:3078633360 M:890925056 WARNING: GetLabel - Unknown nodetype requested 12
10:41:53 T:3078633360 M:891465728 NOTICE: Samba is idle. Closing the remaining connections
2010-01-26, 20:03
wattazoum:
Is there anything special I need to do to update XBMCLive 9.11 (on a 4gb Stick)? I added the repo's, apt found an updated version of xbmc and says it completed, but on reboot XBMC states that it is still the stable (Dec. 24th compiled) version.
I have another PC and XBMC updated without a hitch... did I miss a step?
***EDIT*** I was attempting to upgrade the "xbmc"package instead of "xbmc-live". I corrected my mistake and I am happily on 27017.
Thanks!!!!!!!!!!!!!
Thanks!!!!!!!!!!!!!
2010-01-27, 08:35
Hi all,nice to meet u and I am new here.
This is the frist time to join in here and I will briefy introduce mysely to u.
I like reading and listening to music and sometimes I will go to hike.And i would like to search on internet to find some interesting/ueful things.
So what’s u guys doing?I share things with you and hope u can find more things that you like.
china wholesale
Girish
china wholesale
Girish
2010-01-27, 20:31
The link on the first page, is official ppa (as it says now) the same as "current stable", and therefore currently 9.11? (I installed that one from disc myself).
2010-02-07, 00:28
with command:
get the key for svn
sudo reboot
I did all of this exaclty and I get:
kevin@XBMCLive:~$ sudo apt-get upgrade
The following packages have been kept back:
xbmc-bin xbmc-data xbmc-live xbmc-skin-confluence xbmc-standalone
xbmc-web-pm3
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
I've also tried sudo apt-get dist-upgrade and get the exact same response. How can I get it to upgrade to the latest svn?
