Full Version: XBMC Ubuntu PPAs (precompiled PPA builds for Ubuntu)
luna_s Wrote:this should be stickied
Try This
No nope, edited /etc/init/xbmc.conf with the instructions and verified after reboot.
still no auto login.
possibly because it was an xbmclive version that got updated/upgraded?
even tried manual start.
[email protected]:~$ sudo service xbmc start
start: Job failed to start
edit: for now my way around it is to startx then start xbmc from there.
any help?
Hudson_Hawk04 Wrote:http://wiki.xbmc.org/index.php?title=HOW...Step_Guide
doesnt work in 10.0.4
There is no Login Screen option
System -> Administration -> Login Screen
system >profiles and you can manage logins from there. top lef enable/disable autologin and well its not a complicated Dialog.
if your talking about Linux autologin well then google.
bostoneric Wrote:doesnt work in 10.0.4
run the following from a terminal or alt+f2 if you're a gui person.
gdmsetup
Anyone having problems with playing bluray from the mario PPA?
0613 is the last working date here. Blu-rays just wont play
Henkske Wrote:Anyone having problems with playing bluray from the mario PPA?
YEY someone is boycoting BD's finally....
on a serious note, it is bleeding edge so if you like the old one stick to it.
X3lectric Wrote:system >profiles and you can manage logins from there. top lef enable/disable autologin and well its not a complicated Dialog.
fuggin Wrote:run the following from a terminal or alt+f2 if you're a gui person.
gdmsetup
ok alt+f2 brings up a window. i type "gdmsetup" and nothing happens.
ok again dont see system > profiles in the menus.
and yes i have googled it and tried multiple different things ive found on xbmc forum.
still no luck enabling auto login to xbmc.
I've just figured this out for Ubuntu 10.10
You need to auto start XBMC this way:
System->Preferences>Startup Appplications
On the Tab Startup Programs klik <add>
Now you have 3 input fields:
Name
Command
Comment
Name: you can choose, but XBMC would be the obvious choice.
Command: Click the <Browse> button and navigate to "File System>USR>BIN> scroll all the way down until you find a single entry called xbmc. Select it.
The line in the field Command should now read: /usr/bin/xbmc
Comment: you can leave blank.
DONE!!
I do assume you have alread got Ubuntu to login automagically. It takes a little while longer then a Live install, but it works!
LeechNL Wrote:I've just figured this out for Ubuntu 10.10
Name
Command
Comment
DONE!!
sorry I dont see "System->Preferences>Startup Appplications" so I cant add xbmc to the startup apps
Sad
sorry guys this is a bit offtopic has zero to do with ppas. go here http://www.youtube.com/watch?v=0_BpDe0tqak and here http://ubuntuforums.org/showthread.php?t=1466177 or wherever just refrain form poluting a already complicated thread with non helpfull information regarding its original intent.
I appreciate the help, but neither of those are helpful or things I havent tried.
Guess I'll figure it out on my own or wait till Eden Live version. Oo
Does someone have a clue why I get;
The following packages have been kept back:
linux-generic linux-headers-generic linux-image linux-image-generic xbmc
xbmc-bin xbmc-live
notice when I try to upgrade from unstable ppa and xbmc will not
upgrade. It used to upgrade but no more...help please...
Br, Zemy
sudo apt-get dist-upgrade
