2018-06-30, 11:06
Yesterday and today I have been busy with playing BD with Kodi (including Menu's). I had been a while when I first attempted it and at that time there were some limitations:
Attached I have a debug log:
http://paste.ubuntu.com/p/49fqqtZCcY/
My main question is, should the above mentioned setup work just fine, or should I always need to unpack the ISO to BDMV format (which is far from ideal!).
The network is gigabit wired. Switches and server all have enough power/throughput to deliver 1gbit.
Please let me know if I can help with additional info or tests. Would, be great if ISO's can play.
(I do not know what the current limitations to BD are -> except that libbluray is re-engineered and always one step behind is).
- NFS share was impossible to use for playing BD;
- Not all Menus work;
- ISO did not work at all for BD;
- Some other I forgot.
- NFS is working fine;
- Menus tested so far all work;
- ISO BD work for the menu part;
- xXx: Return of Xander Cage (2017).iso -> gives stutter on the main movie;
- Ant-Man (2015)/BDMV/ -> plays just fine.
