2018-07-01, 16:25
2018-07-01, 16:38
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
2.Restart Kodi
