I just compiled XBMC on opensuse and it's sweet! I can now ditch my old Xbox
I only have one problem: I use a remote that generates a sequence of buttons for one press, because it's actually detected as an HID device. For example, PLAY produces three buttons (LEFTCTRL, LEFTSHIFT and P). With .lircrc file, that's not a problem since I can enter multiple "button" directives and it works. However, XBMC bypasses that file. I was wondering if it's possible to do the same with XBMC?
Since I got no replies yet, I'm posting a workaround I use in case someone else has the same problem. What I ended up doing is configuring irxevent to send keyboard shortcuts to xbmc when it detects the lirc sequence. All this is configured in the .lircrc file. The downside is that I have to have irxevent running. I'm still hoping for a much more elegant way (ie having native support in xbmc for sequences) as this is an ugly hack, at best!
Wow, that is an old thread, you are lucky I'm subscribed to the thread
What you have to do is create a .lircrc in your home directory and then have entries like that:
begin
prog = irxevent
button = LEFTCTRL
button = P
config = Key space xbmc.bin
end
Make sure that both irexec and irxevent are running and on the same diplay. My script to start xbmc looks like this:
DISPLAY=":0.1" xbmc -q &
DISPLAY=":0.1" irexec &
DISPLAY=":0.1" irxevent &
I hope that helps.
And how do you configure lirc to use the USB keyboard device?
I have a remote I got from dealextreme. Basically, it behaves just like a keyboard.
First, I have a rule in udev to make the symbolic link:
KERNEL=="event[0-9]*" SYSFS{idVendor}=="04b4", SYSFS{idProduct}=="0100", SYMLINK="input/remote"
Then in /etc/lirc/hardware.conf, make the following changes:
REMOTE_DRIVER="dev/input"
REMOTE_DEVICE="/dev/input/remote"
START_LIRCD="true"
Finally, you need to copy paste the file
http://linux.bytesex.org/v4l2/linux-inpu...lircd.conf in /etc/lirc/lircd.conf
That shoudl do it.
looks like im getting somewhere, as i also have a cheapo remote frome dealextreme too (
http://www.dealextreme.com/details.dx/sku.27596 ) and after getting nothing from irw and pressing the buttons, the code being typed in terminal was stuff like ^[[C which was the same when i press the left arrow on the attached keyboard.
sorry to be such a linux noob, but can u explain what u mean by
First, I have a
thats the only bit i don't get sorry.
once i get this done i think i'll be able to get ir commands that emulate press of the c, s and i keys!
oh and should i have 'remote control sends keyboard presses' enabled?
ta
