2018-07-12, 08:45
2018-07-12, 09:07
We don't even know what the problem is by the wonderfull explanation you gave
A bit more info might be useful, probably
2018-07-13, 05:15
When i click install app in apps it goes to the media center
2018-07-13, 08:33
Which app?
What media center?
You're just not providing enough information to clarify what your issue is.
Please explain the problem using more than just one short sentence. Include specific details such as what hardware you're using and what it is you're trying to do. Are you trying to installl Kodi from the Google app store and running into an error?
What media center?
2018-07-16, 06:57
I have an MXq android TV box running kodi 17.1.2. When i go to install an app and click on install app in the app directory, it goes to the media center.
Cheers
Cheers
2018-07-16, 12:06
I think there's a communication issue here, you're still not making any sense or providing enough information.
Break down what you're doing step by step and provide as much information about each step as you can. One sentence replies are just causing frustration and will probably end up with the thread being binned after a while.
If English is your second language it might be better to write out a detailed response in your native tongue and posting that and a google translated version so we might have a better idea.
