2018-07-12, 15:56
2018-07-12, 16:38
@artfullone
Please note that the Kodi forum has a maximum of 4 text lines as a forum rule.
So, get creative with displaying your signature horizontally.
2018-07-12, 17:06
(2018-07-12, 16:38)Klojum Wrote: [ -> ]@artfullone
Done
2018-07-22, 16:59
Anyone?
2018-07-24, 14:44
2018-07-27, 15:34
Hi.
Includes_Header.xml doesn't exist but Includes_Home.xml does.
But the below changes didn't change the footer height.
xml:
<!-- Home Row -->
<control type="group">
<animation effect="slide" start="0" end="0,250" time="150" condition="!Skin.HasSetting(home.classicwidgets) + [Control.HasFocus(301)]">Conditional</animation>
<animation effect="slide" start="0" end="0,250" time="150">WindowClose</animation>
<animation effect="slide" end="0" start="0,250" time="150">WindowOpen</animation>
<control type="image" description="BottomBG">
<width>100%</width>
<height>120</height>
<bottom>0</bottom>
<aspectratio aligny="bottom">scale</aspectratio>
<texture colordiffuse="Background">common/bg.jpg</texture>
<animation effect="fade" start="100" end="75" time="200" condition="true">Conditional</animation>
</control>
<control type="image" description="FanartOverlay">
<width>100%</width>
<bottom>0</bottom>
<texture colordiffuse="FloorFade">common/floor.png</texture>
</control>
2018-08-02, 13:20
First, do backup copies!
Ok, to reduce the footer height open in Artic Zephyr, ver. 2.3.13:
includes_home.xml,
line 1302
lines 622, 630 and 630
lines 644 an 653
to change verticaly Position of Clock, open:
includes_furniture.xml,
line 1108
to change verticaly Position of submenu, open:
includes_home.xml,
line 714
Change the values as you like, save the file an reload your Skin!
includes_home.xml,
line 1302
(moves the noicon-menu vertically)(xml:<top>948</top>
(changes the Background height)xml:<height>220</height>
lines 644 an 653
(moves the arrows vertically)xml:<top>962</top>
line 1108
(moves the clock vertically)xml:<centerbottom>NavBarPad</centerbottom>
includes_home.xml,
line 714
(moves the submenuvertically)xml:<posy>460</posy>
2018-10-01, 13:03
