I'm comparing a 4K HDR version of "The Matrix" to an 1080p HD version.
Playing on Kodi 18 nightly build using pixels shaders as render method.
To me it seems like the colors are more loyal to the source on the HD version, while the 4K HDR one seems a bit too green-ish.
Interested to hear your opinion.
The HD version:
The 4K HDR version:
My system info
The Matrix 4K - MediaInfo
The Matrix HD - MediaInfo
It does look a little green. It's a tough comparison. To grade a 4K HDR source, you can't simply turn up the brightness knob on the 1080p version. You would have to change the color balance slightly to keep it from looking overcooked on a 1,000 - 4,000 nits mastering display. Using higher saturation is also a technique to separate the 4K HDR version from the 1080p version when it comes to catalogue titles. These comparisons are always difficult without seeing the original 4K grade.
The system info doesn't appear to be available. What is your GPU set to output as far as color format, range and depth? When the HDR version is being played are you setting the Windows 10 HDR setting set to On?
Well, the new 4K bluray has been mastered a bit more greenish than the old HD bluray. At least in the 'in the matrix' scenes. So it's difficult to judge whether these screenshots conform to 'the source' when they're both from different sources.
(2018-07-13, 05:22)drpizznock Wrote: [ -> ]The system info doesn't appear to be available. What is your GPU set to output as far as color format, range and depth? When the HDR version is being played are you setting the Windows 10 HDR setting set to On?
I fixed the link, not sure what happened there.
I just noticed the Windows 10 HDR setting was Off (I was fiddling with it before when I tried DSPlayer + madVR and someone suggested to turn it off).
I'll edit the original when I'm home and add a 4K HDR one when Windows 10 HDR is on.
(2018-07-13, 11:13)willemd Wrote: [ -> ]Well, the new 4K bluray has been mastered a bit more greenish than the old HD bluray. At least in the 'in the matrix' scenes. So it's difficult to judge whether these screenshots conform to 'the source' when they're both from different sources.
That's a good point!
So you're saying perhaps each is loyal to its own source.
The only to know for certain would be to compare with a UHD disk player or perhaps one of the commercial apps such as PowerDVD.
(2018-07-13, 17:01)jjd-uk Wrote: [ -> ]The only to know for certain would be to compare with a UHD disk player or perhaps one of the commercial apps such as PowerDVD.
That still wouldn't help unless your display is as bright as the mastering display. You are just substituting the display's tone mapping for Kodi's. It's still tone mapping. You can't assume the tone mapping of an HDR display is reference.
Well it seems turning on Windows 10 HDR did absolutely nothing in terms of the image. Is that out of the ordinary ?
Did you turn HDR on in your display for the port your computer is plugged into? Quite honestly, every picture you've put up here and in other threads doesn't look HDR at all.
It looks like these are actually Kodi screenshots. If so, they will never have HDR or BT.2020 color profile.
It is tone mapping the result to SDR. The result would largely be dictated by the brightness of the display in SDR mode as well as the choice of tone mapping algorithm.
There is no support for HDR passthrough.
If you do send an HDR signal to an HDR display, it will also tone map. I have seen many images tone mapped to both DCI-P3 and BT.709. There is barely a difference in color saturation (less than 26%). Brightness and choice of tone mapping curve make a far bigger difference in making HDR accurate to the source. And a source can still look HDR at a lower brightness. The SDR range is clipped at 100 nits, so an HDR image shown at the same brightness as SDR is typically darker but has greater contrast. The implementation of tone mapping will influence the result greatly of course.
An HDR display has a dedicated mode with a higher peak brightness than SDR mode and the ability to tone map a PQ input. It’s not doing any magic to make the image look HDR.
The Kodi implementation is Reinhard tone mapping, I don't know what the difference between different algorithms is or the technical details, best I could come up with after I saw it was added was
https://learnopengl.com/Advanced-Lighting/HDR
Thanks for the link. It is at least a reference.
That link does detail digital photography and not HDR video, though.
In PQ HDR, every input would already be between 0.0 and 1.0. An input PQ value of 0.2, for example, would be scaled by 25 for a 400 nits curve (10,000/400 = 25). So 0.2 x 25 = 5.0, which would have to be tone mapped from 5.0 to 1.0 to fit a 400 nits curve.
Heavy range compression never goes well when it comes to color accuracy and things like image detail being flattened. At least the algorithm chosen is based on science, but I'm not convinced it is color corrected. Just putting something through Reinhard would produce an okay result but not ideal. If you do a search for "color correction for Reinhard tone mapping," you would likely find a bunch of research papers with different methods.
With that said, I haven't tried the latest build, but it doesn't look that bad.
Reinhard was meant as a start. An example PR that shows howto integrate other shaders / algorithms into kodi. You can consider it as a blueprint for contributors. No one from team kodi says that this is the best tone mapping algorithm delivered by science :-) (it is not). But if it fits the needs of most of our users then it's even a usable blueprint, which is really great.
