Installing IPTV Simple client to a new Firestick today.
Kodi 17.6 . Once i enable the IPTV Simple Client the app crashes and boots, then crashes.
Had to install SPMC where it was fine.
Wiped it all and reset but this keep's happening.
Any idea's guys?
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
I have almost the same problem. But can't restart to enable debug log. When I try to start Kodi it starts up, show scren a few seconds and then stops.
Any tips?
Same problem here!! In my pc I was force to update to Leia and it´s running fine but not in my Sony Android Tv. In my tv my kodi does work when I just use others addons but when I set up my IPTV Simple Client crash and boot.
I would like to try Leia (android) but is not available in the Google Play (Store)
Thaks
I'm on Kodi 18 now and issue is fixed.
Nice! I did the same in my pc but still the same problem in my Android TV because they don´t have the kodi 18 on google play.
