I just discovered that the xbmcgui.busydialog is going away. Personally, I thought the Busy Dialog in V16 looked better than the one in V17. Using the ProgressBar Dialog as a Busy Dialog isn't a good alternative because it just doesn't look good. So my question is this: will there be a replacement busy dialog in V18 that will look cool?
I think you can use "busydialognocancel" instead.
(2018-07-23, 00:49)xodi Wrote: [ -> ]I think you can use "busydialognocancel" instead.
Xodi,
Can you tell me where that function is documented? I don't see it anywhere in the V18 xbmcgui docs. It also didn't show when I performed a Google search.
It's a workaround for the dialogbusy removing. You can get it from the related PR in the xbmc github.
(2018-07-23, 06:28)xodi Wrote: [ -> ]It's a workaround for the dialogbusy removing. You can get it from the related PR in the xbmc github.
I never found the PR but did find a reference in a header file.
How would I execute that busy dialog from within my Python code?
Can't get it to work? Same here...workaround.. LOL
to open the dialog:
python:
xbmc.executebuiltin('ActivateWindow(busydialognocancel)')
and to close it:
python:
xbmc.executebuiltin('Dialog.Close(busydialognocancel)')
Cheers, I was trying to use..
xbmcgui.DialogBusyNoCancel
Obviously totally wrong
I'd recommend to wrap it in a context manager:
python:
from contextlib import contextmanager
@contextmanager
def busy_dialog():
try:
yield
finally:
with busy_dialog():
# Do your stuff
This will guarantee that your busy dialog will be closed whatever happens inside the
with block.
I tried running xbmc.executebuiltin('ActivateWindow(busydialognocancel)') under V17 and no busy dialog showed up.
Am I correct to assume that this feature only works under V18?
