Is there any way to have Kodi refresh its metadata from the .nfo files as a whole? I've gone through and edited a ton of these with correct set information, now I need Kodi to pick up the changes.
'Change content ' in the video 'source' menu, set the scraper to local information only, on exit you will presented with a request to scrape entire source... choose 'yes' sit and wait, your .nfo will scrape if the format is Kodi compatible. Don't forget to change the scraper back to your choice after the scrape.
Great! Thanks! I'll give it a shot.
Well the thought was good but it only scanned about 8 movies. My library is much larger than that. What could be causing it to fail? Are there logs for this somewhere?
Sorry, nevermind, it worked. I don't know what was the issue the first time. Thanks again!
