Either install a support mesa / libdrm version or disable VAAPI
hi i have installed these libs on my S.O, is correct? what libraries I would be lacked
Quote:libdrm-dev is already the newest version (2.4.74-1)
libdrm-common is already the newest version (2.4.91-2~bpo9+1)
i don't know how uninstall or disable vaapi
What you are you building for? Looks like some totally outdated "debianish" thing.
Edit: Your libdrm-dev does not match the rest at all. Fix your system first, please.
i'm build kodi to make an addon.
what version of libdrm-dev i needed?
2 4.91 is enough for dev and lib
(2018-07-23, 21:29)Edoar Wrote: [ -> ]libdrm-dev is already the newest version (2.4.74-1)
Install libdrm-dev from stretch-backports too like you already did for libdrm-common.
