Hi, I am having a problem getting audio to play the my home theater receiver unless I completely disable my pc speakers. I have an hdmi card going to my receiver . And when I check my settings the audio is set for my receiver both in the first setting and in passthrough. I am using 18.0-1 alpha 1. Thank you!
I tried turningĀ the receiver on before starting kodi and that did not work.
rufusmcd
Next time, stick to posting your thread once, and not twice
Also, it's okay to edit your own post and add some text to it.
If you are using Alpha software, always upgrade to the latest nightly build first. We are not going to fix things separately on Alpha builds.
I apologize for that, I was trying to fix a typo
And can you do an update or do you have to uninstall and reinstall?
