After using the scrapper for a bunch of movie folders. Some of the thumbnails were incorrect. I tried to change the thumbnail using the get thumb option. The option allows me get new thumbnails but when i select a new one they do not change.
I found many forum but i haven't found any solution to solve. Any canĀ figure it out. Thanks!
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
