2018-08-01, 10:13
So I setup Maria DB5 and phpadmin, made a kodiuser and then automatically databases appeared wihen I put approperiate advancedsettings.xml in my local kodi windows user folder.
It made the MYSQL databases in phpadmin.
Then I imported my singlefile database on the windows PC.
And in windows it loaded them up with thumnails and all and I can play them sucessfully!
Then I close kodi and open it and it shows them all perfectly.
So I put the exact advancedsettings.xml on the userfolder in the libreelec box.
And I reboot.. Upon reboot I see all items just like on pc. with 2 differences...
I don't see any thumbnails. And when I try to play ANY movie it will say "this file is no longer available"
I have some manual links that i added before to these same network sources (a folder above it)
And I can access it just fine.
So what is the deal here, why can't it see my movies?
I know there is this thing about SMB and windows 10 at the moment. But like I said I can see my previously added network paths fine.
I have added SMB1 back to windows 10.
Not sure what the "minimum required SMB" and "maximum required SMB" versions need to be on respectively in librelec.
But I can't imagine with what I said to be the source of the problem..?
