Fwiw, I am experiencing this as well on one of my machines.
8:09:13.034 T:2609904448 ERROR: CCurlFile::Open failed with code 0 for https://mirrors.kodi.tv/addons/leia/plugin.audio.radio_de/plugin.audio.radio_de-2.3.2.zip:
08:09:13.034 T:2609904448 ERROR: Could not fetch addon location and hash from https://mirrors.kodi.tv/addons/leia/plugin.audio.radio_de/plugin.audio.radio_de-2.3.2.zip
08:09:13.044 T:2609904448 ERROR: CAddonInstallJob[plugin.audio.radio_de]: failed to resolve addon install source path
Kodi version is Kodi (18.0-BETA3 Git:20180919-fea8a29). Platform: Linux x86 32-bit, Running on Ubuntu 16.04.5 LTS, kernel: Linux x86 32-bit version 4.4.0-135-generic, Host CPU: Intel® Pentium® 4 CPU 3.00GHz, 2 cores available.
Downloading the required addon directly from the mirror and installing via zip works fine.
I tried a nightly build again yesterday and this still isn't resolved.
When will the nightly builds have the new version of curl?
I have installed kodi on android tv ,and i can not install nothing from repository,it is keep coming eror "could not connect to repository"
(2018-10-11, 17:27)bokod Wrote: [ -> ]I have installed kodi on android tv ,and i can not install nothing from repository,it is keep coming eror "could not connect to repository"
Sorry, we have no crystal ball here. Please provide a
debug log (wiki) for starters, or tell us at least which repository this is about.
Just installed Latest nightly compiled on the 10th October onto a brand new Intel NUC Mini Pc running Windows 10 Pro and cannot install anything from Kodi Official repository. Also tried the Beta 3 build, but seeing exactly the same behaviour. Tried installing Netflix, Amazon and Artwork Beef repo's, but none install. I just get a dialog saying 'Could Not Connect to Repository'.
Strangely, the EmbyCon addon installed no problem from the Emby beta repo, so at least one repository seems to be working.
Debug Log attached:
https://pastebin.com/ewBsCN4a
(2018-10-11, 17:31)Klojum Wrote: [ -> ] (2018-10-11, 17:27)bokod Wrote: [ -> ]I have installed kodi on android tv ,and i can not install nothing from repository,it is keep coming eror "could not connect to repository"
Sorry, we have no crystal ball here. Please provide a debug log (wiki) for starters, or tell us at least which repository this is about.
Multiple debug logs have been posted in this thread and the Kodi Team hasn't responded to any of them or acknowledged this as a bug.
Update - Downloaded Windows 32bit version of Kodi, as suggested earlier in this thread and works with no problem. After installing all my regular addons from their relevant repositories, I wondered if I would be able to update to the 64bit version, which I was able to successfully install and my addons are still working fine. Only problem is, whilst the repositories are accessible, if I try to install anything new it fails.
Does this mean I'm going to be limited to the 32bit version of Kodi only? Grateful for any feedback.....
64bit works just fine for installing from Kodi repo
(2018-10-14, 14:04)Martijn Wrote: [ -> ]64bit works just fine for installing from Kodi repo
This bug is only on 64-bit with certain Intel processors where curl is seeing a different digest on everything from what it expects. Multiple people are reporting this. Debug logs have been posted multiple times. But it seems no one will ever acknowledge this bug or fix it.
20:40:33.237 T:6268 ERROR: CCurlFile::FillBuffer - Failed: SSL connect error(35)
20:40:33.237 T:6268 ERROR: CRepository:
http://mirrors.kodi.tv/addons/leia/addons.xml.gz index has wrong digest 649b934c649b934c7852b8557852b85527ae41e4649b934ca495991b7852b855, expected: 915f09cd6841766459c48bfa79bf3f601d436983ef3e0cd547991413aca50006
20:40:46.977 T:6268 ERROR: XFILE::CDirectory::GetDirectory - Error getting
20:40:50.660 T:6268 ERROR: Previous line repeats 6 times.
20:40:50.660 T:6268 NOTICE: VideoInfoScanner: Starting scan ..
20:40:52.607 T:6268 ERROR: CCurlFile::FillBuffer - Failed: SSL connect error(35)
20:40:52.607 T:6268 ERROR: CCurlFile::Open failed with code 0 for
https://api.tmdb.org/3/search/movie?api_...anguage=en:
20:40:52.607 T:6268 ERROR: ADDON::CScraper::Run: Unable to parse web site
Will you fix it?
If not then you will have to wait till someone finds time, figures out why and then try to solve.
Really? I've just downloaded the latest 64bit version within the last 45 mins from the official Kodi repository and this is what I get:-
The 3 addons pictured above were all attempted to be installed from the official Kodi repository and all failed as you can clearly see. The only other repo's I have installed from the previous 32 bit installation are Netflix, Amazon, Skin Helper Script and Artwork Beef which all work in that version of Kodi, but not in the 64bit version.
A log has previously been submitted, so not sure what additional information I can provide?
Grateful if you could advice what else users can do to advance this forward as an issue?
(2018-10-14, 19:02)Martijn Wrote: [ -> ]If not then you will have to wait till someone finds time, figures out why and then try to solve.
oops! Just seen this reply was posted prior to my last post.....soz
Okay, fair enough. Happy enough to continue with the 32bit version just now.
Maybe the images I posted will be of some use still.....
As tested by me in a previous post, is just a matter of replacing cURL and OpenSSL libraries with newer (?) versions.
I don’t know how cURL/OpenSSL is compiled in Kodi, but maybe some optimization doesn’t work with NUC Celeron CPU.
You can use latest cURL and an OpenSSL build providing libeay32.dll.
