Well spent an hour to find this sll error in debug log and no access to kodi repro. Just installed 32bit version and kodi is working.
So avoid 64bit version and save time and trouble nobody seems to care...
Indeed we don't give a damn. Happy?
Hello. I confirm: I have two systems Asrok j5005 and j4205, Windows 10pro\ent. On both, I see the same problem with KODIx64. I also have a computer on Core I5 3570K - there is no such problem on it.
Rechi, this build (KodiSetup-20181028-9dfb0304-windows-openssl-x64.exe) works on ASRock J4105-ITX (Windows 10 1607 LTSB). Connect to repository - YES. Download addons - YES. Thanks!
sorry for my English, I'm from Ukraine.
troffim as you haven't reported about any issues before in this thread, is installing from repo broken for you with nightly builds?
Rechi, I use Kodi v18 for only a few days, I thought that connecting to the repository is a temporary developer problem. Now everything works fine, thanks again!
Sorry for my English.
(2018-10-29, 01:27)Rechi Wrote: [ -> ]Please retry with http://mirrors.kodi.tv/test-builds/windo...sl-x64.exe and report back.
Same here on my NUC Mini, using Win10 Pro. Everything working as expected. I can also set/edit PVR Timers again now, without having to do that from a different device.
A huge thanks for your time and effort. Very much appreciated
I can also confirm that it works on an ASROCK J4205 with Win10 Pro.
Fix is in Kodi 18.0 Beta 5 and in last nightly (KodiSetup-20181103-*).
(2018-09-24, 22:16)ilGimmy Wrote: [ -> ]if curl is the issue, you can download it from https://curl.haxx.se/download.html (in the past I fixed a similar problem extracting libcurl.dll from Stefan Kanthak cab file).
I'll try and report back...
edit:
Kodi 16b2 on NUC6CAYS
I installed libcurl.dll from https://skanthak.homepage.t-online.de/do...7.61.1.cab and got same error.
then I replaced libeay32.dll with the one from openssl-0.9.8h-1-bin.zip (https://datapacket.dl.sourceforge.net/pr...-1-bin.zip) and it worked!
I think openSSL need to be checked.
Of secondary importance, this issue also impacts 64-bit Kodi DSPlayer. I was racking my brain over this for a good half day until I stumbled on this thread, to which I can confirm that not only Apollo Lake and Gemini Lake processors (e.g. the Pentium J4205, Pentium Silver J5005) are affected, but the most recent Intel Ice Lake processors (e.g. the Core i7-1065G7 found in the Surface Pro 7 exhibits the same behavior) are directly impacted by this bug. Fortunately, this issue has already been patched in the main development branch of Kodi which concerns 99% of this forum so this is a non-issue for most users here. However, for the few impacted 64-bit DSPlayer users, bear in mind that you will need to manually copy and replace the two .dll files (libcurl.dll and libeay32.dll) in your Kodi program folder (i.e. "C:\Program Files\Kodi\"). You can get these files from the following two links below. In the case of libcurl.dll, make sure to pull the version under the AMD64 folder since you specifically need the 64-bit version of the library:
https://sourceforge.net/projects/gnuwin3...p/download
I will be cross-posting this in the
Kodi DSPlayer thread in the hope that others who are impacted also read this. Perhaps it can be integrated into a custom release there at a future date.
