I've tried all the suggestions I could find- updating TVDB scraper, putting shows in their own folder, using the correct naming structure... Missing something here.
I have Kodi 17.6, TVDB 3.0.7 running on an Amazon fire TV 4k.
File structure-
//TV Shows/Show title (year)/TV_show_name s00E00 episode_title.ext
When I search for the shows on TVDB web page, they all show up
Moves are scraped fine.
Hello @
dr_zapp
So far your setup looks fine. We will need a
Debug Log to see what the problem is.
- Enable Debugging mode. Go to Settings>System Settings>Logging and it should be the first option
- Restart Kodi
- Replicate the problem. Attempt to scrape your problem TV Show.
- Upload the log to https://paste.ubuntu.com/ manually or use the Kodi Logfile Uploader. With either method post the link back here.
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
OK, I got this used, it came with a bunch of stuff installed that I don't even use... I just need to remove everything on the blacklist?
Yes. but you have so much of it that it would be better if you perform a Fresh Start.
So I did the fresh start, and now it appears to be working fine- Thanks for the help!
Great. I'll mark this as solved.
