Full Version: Can connect via web broswer - cant via KORE
i have an issue - i can connect via browser (e.g. chrome), but for some reason kore with them same IP, port, username, password just wont connect.
Settings of kodi connected via web browser to raspberry pi
https://imgur.com/jG6DJhF
https://imgur.com/QsO2def
kore connection settings:
https://imgur.com/a/1sTm8Uh
i also can ping my raspberry pi - cmd - ping 192.168.10.232 ping 4ms
Why cant i connect Sad ?
Your settings look alright. Just don't forget that you need to be on the same network for kodi and kore to communicate. I guess you're using kore on your phone, so you're accessing the network via wifi, make sure that any router you have isn't blocking port 8080. The fact that you're able to connect via webinterface might not mean much, unless you're on the same device as kore.
