2018-08-06, 04:22
2020-05-17, 06:06
Is this addon still working?
2020-05-17, 17:33
(2020-05-17, 06:06)cyn00 Wrote: [ -> ]Hi,
Yes, Last I checked.. However, if you are running Kodi Matrix; All plugins are incompatible till I push an update for that branch.
If you are still encountering issues with Kodi Krypton/Leia please post the problem along with a debugging log.
2020-06-05, 02:23
(2020-05-17, 17:33)Lunatixz Wrote: [ -> ](2020-05-17, 06:06)cyn00 Wrote: [ -> ]Hi,
2020-06-05, 02:24
I can't get it to work, I would really appreciate any help you can give. A link to my log is below.
https://paste.kodi.tv/fihotosaqa.kodi
Thanks,
Cyndi
Thanks,
Cyndi
2020-06-05, 15:43
The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
2020-06-07, 09:09
2020-06-07, 10:09
@cyn00 - if you want support here then we need a full and clean bug log, without bits chopped out of it and without any banned addons (wiki) installed on the device.
Otherwise your section of this thread will be cut out and sent to the bin.
2020-06-07, 23:41
2020-06-08, 09:02
Better, although you've still got some orphaned scripts and some widgets running that are referring to the banned addons (wiki) (and doing who knows what else on your system in the background...).
The simplest way to remove the orphans is to close Kodi, then open Windows File manager, go to C:\Users\Cyndi\AppData\Roaming\Kodi\addons and delete each of the folders of the scripts listed above. You'll also need to remove the widgets yourself within Kodi.
2020-06-07 14:36:12.877 T:1424 NOTICE: ADDON: script.exodusredux.artwork v1.0.2 installed
2020-06-07 14:36:12.877 T:1424 NOTICE: ADDON: script.exodusredux.metadata v1.0.2 installed
2020-06-07 14:36:12.878 T:1424 NOTICE: ADDON: script.module.exodusredux v2.0.5 installed
2020-06-07 14:36:12.878 T:1424 NOTICE: ADDON: script.xxxodus.artwork v1.00.018 installed
2020-06-07 14:36:12.878 T:1424 NOTICE: ADDON: script.xxxodus.scrapers v1.00.025 installed
2020-06-07 14:37:21.092 T:1424 DEBUG: CDirectoryProvider[plugin://plugin.video.exodusredux/?action=movieNavigator]: refreshing..
2020-06-07 14:37:21.092 T:1424 DEBUG: CDirectoryProvider[plugin://plugin.video.exodusredux/?action=tvNavigator]: refreshing..
2020-06-07 14:37:21.092 T:1424 DEBUG: CDirectoryProvider[plugin://plugin.video.exodusredux/?action=searchNavigator]: refreshing..
2020-06-07 14:37:21.092 T:1424 DEBUG: CDirectoryProvider[plugin://plugin.video.exodusredux/?action=movieWidget]: refreshing..
2020-06-07 14:37:21.092 T:1424 DEBUG: CDirectoryProvider[plugin://plugin.video.exodusredux/?action=tvWidget]: refreshing..
2020-06-07 14:37:21.092 T:1424 DEBUG: CDirectoryProvider[plugin://plugin.video.exodusredux/?action=docuHeaven]: refreshing..
2020-06-07 14:37:21.092 T:1424 DEBUG: CDirectoryProvider[plugin://plugin.video.exodusredux/?action=mymovieNavigator]: refreshing..
2020-06-07 14:37:21.092 T:1424 DEBUG: CDirectoryProvider[plugin://plugin.video.exodusredux/?action=mytvNavigator]: refreshing..
2020-06-08, 09:26
Please delete.
2020-06-08, 09:45
You've missed one -
2020-06-08 00:19:40.349 T:11956 NOTICE: ADDON: script.module.exodusredux v2.0.5 installed
2020-06-12, 02:24
2020-06-18, 01:35
Is my log OK now?
2021-02-27, 15:36
please port it to Matrix
Thx
Thx
