2018-08-07, 02:43
2019-08-29, 22:09
Is this plugin working for you matt? I can browse, but not play - although I used to be able to....
If it's working for you then I'll go dig into the logs and see if I can't debug it myself
2019-08-29, 22:55
(2019-08-29, 22:09)klendool Wrote: [ -> ]Is this plugin working for you matt? I can browse, but not play - although I used to be able to....
You may need to update Widevine.
Go into it's add-on settings and click "Install Widevine DRM"
2019-08-30, 22:15
(2019-08-29, 22:55)matthuisman Wrote: [ -> ](2019-08-29, 22:09)klendool Wrote: [ -> ]Is this plugin working for you matt? I can browse, but not play - although I used to be able to....
Thank you very much, that was the issue
2019-08-30, 22:24
Thank you very much - that worked well!
2019-08-30, 23:14
(2019-08-30, 22:24)klendool Wrote: [ -> ]Thank you very much - that worked well!
I also pushed an update yesterday so any new widevine version will automatically be detected in the future
