2018-08-08, 04:38
So I have several frontend nvidia shields working great with a mysql backend.
The problem is after some amount of time (I think I've only seen it after the shield sleeping).
Upon waking, sometimes files I know are there will claim to not be. Ways to fix:
1. Exit kodi and restart it. Without any library updates or other library modifications, things seem to work again.
2. It seems like if I watch a file that's already marked as watched, a file that hasn't been watched will start working again. I'm not sure if this is coincidental, but it just happened
This is using an SMB connection where the file location is smb://<ip address>/media/movies/blah.mkv. I started using IP address just in case there was resolution issues causing this.
I searched the forums but didn't find anything that might explain this. Perhaps it's nvidia shield hibernatel related? But I thought kodi was pretty much in control of the smb connection when you're using a network share method.
