2018-07-26, 21:35
2018-08-02, 01:39
I've been using kodi for several years now and love it. I finally decided to convert my dvd's and make my own video library. I bought a NAS and set it up with mhPHPadmin to setup an SQL to access through kodi. Got it all up and running and couldn't be happier except.....now, if I turn my VPN (IPVanish) kodi won't work until i turn it off. Help!
Android G-Box2
Kodi and VPN have been working fine, I believe it has to do with either a Kodi setting (something about kodi trying to access NAS but NAS doesn't recognize the G-box IP anymore?) or the advancedsetting .sql file is not correct?
Android G-Box2
2018-08-02, 01:52
@jjulien31
A VPN is a 3rd party modification outside the scope of this forum. You do not need a VPN to use Kodi, especially when accessing local media. We are unable to assist you.
I suggest you contact the Help Desk of your VPN Provider.
Moved.
Moved.
2018-08-05, 14:16
What if your ISP blocking some addons or links to run on kodi. Most of kodi users suggesting to use vpn with kodi
2018-08-05, 14:20
2018-08-26, 06:47
i have a paid vpn just wondering if i really need it with kodi or other apps i heard you need a vpn to download and watch streams and so isp dont know what your up too. is there anyone who hasnt used a vpn without precussions
2018-08-26, 06:52
2018-08-26, 08:56
You only need vpn if you plan to do illegal stuff
2018-08-26, 09:02
@Plantje
Not 100% correct. We recognise that there are legitimate uses for a VPN, but the use of them is outside the scope of this forum, and Kodi works perfectly well without one. We see it as a 3rd party modification.
As most people will be paying for that service, then they will need to contact the paid support services of the VPN provider for assistance.
2018-08-29, 07:42
(2017-01-22, 18:51)GarDogTV Wrote: [ -> ]Does *bleep* work for Kodi?I think *MOD-EDIT* is an excellent choice to start with.
If so, is it any good?
What VPN do you recommend?
No advertising of VPNs on this forum.
2018-08-29, 07:56
(2018-08-29, 07:42)Soion Wrote: [ -> ]I think...I think you should read the forum rules (wiki) of this forum you just registered to more closely.
This is not a place for VPN advertising. VPN is not essential for Kodi to run.
2018-08-31, 19:00
Thread moved to off topic
2018-09-21, 12:51
Hello,
I try to use the Kore remote control, but i must disable the computer's VPN, otherwise the connection is lost. But a VPN is also activated on my phone and it doesn't give me any problem.
2018-09-21, 12:55
Please read our VPN policy (wiki)
2018-09-21, 13:09
So...does it means that the blocking of any connection to my phone if i'm using a VPN on my computer is deliberated ?
