hi all as the title suggests i cannot figure out how to add anything into these tiles any help would be much appreciated thanks in advance
Hi djwayne,
You cannot add an addon to the widget tiles (spotlight, etc.), the addons could only be added to the tiles with a + sign (just go on the tile and select it to be prompted with the options).
If you want to modify the widget tiles, you can go in the skin settings, under 'Home' category and 'Manage custom Home Widgets' or alternatively select the one you want to modify and press backspace on your keyboard.
At the same place you can select 'Manage custom Home Items' to modify the addons you want to display on your home screen.
Can you remove these widgets from the Home screen? I can't seem to do it
