hello to all I finally solved the problem of passthrough installing kodi 18 beta Shitty version. But now I have two other problems:
-The scraper no longer work well. They only recognize a few films. I use TMDB and universal Scraper
-If I gauge the screen as soon as I turn off Kodi and then turning it back on it will return to default
vicius80
Can you provide a
Debug Log which captures you scraping your library. Also tell us the name of one or two films that will not scrape.
Not sure what you mean by "If I gauge the screen"
I mean the scraper. with this version 18 shitty the scraper with universal scraper or TMDB does not work.
if I install the 18 alpha3 the scraper is ok but the DTS passthrough does not work
can you help me?
(2018-08-16, 00:43)vicius80 Wrote: [ -> ]I finally solved the problem of passthrough installing kodi 18 beta Shitty version.
(2018-08-16, 01:26)vicius80 Wrote: [ -> ]with this version 18 shitty the scraper with universal scraper or TMDB does not work.
If you're just trying to piss us off, don't bother asking for shitty support here.
(2018-08-16, 02:35)tjay260476 Wrote: [ -> ]I'm not siding with anyone here, but if you look at
Thanks, I just already found out myself. :o)
vicius80
Sorry, apparently there was such a thing as a 'shitty' apk installation file. I wasn't aware of it.
But are you still using that shady stream box of yours?
And where is the
debug log (wiki) that was requested?
