2018-08-20, 02:45
Hello,
I was using kodi on my android (4.1) box, but tonight android box dir .
Im not able to start the android box it look like the cpu overheated and leaked. I was runing kodi from sd/usb, usb drive in my case all data files are on the usb drive is there a chance to use the data files somehow on new device and restore all my addons and settings (watched movies, ip tv settings and etc) on new android box devices.
If i find the same version who i have and install it, and after install i delete the kodi folder data, and create xbmc.data and add xbmc.data=/storage/sdcard1/Kodi-data, will it work and everything be back?
Btw if i install newer version is it possible to use the same think to setup the newer version to work from disk and add the kodi _data who i have now?
