Full Version: more categories in the home layout?
Hi!
I'm using the Amber skin for years now but there's some little things bothering me.
Is there any possibility, or is it planned on a future version of the skin, to add more categories in the home layout?
I use various smart playlists and external apps like: movies, movies for kids, tv shows, tv shows for kids, netflix, prime video, retrogaming, etc... and i'm kinda limited by the skin right now.
Even better: the possibilty to group some smart playlists under one category in the home layout, for example :
MOVIES
  > MOVIES
  > ANIMATION MOVIES
TV SHOWS
  > TV SHOWS
  > Cartoons
  > ANIME
VOD
  > NETFLIX
  > PRIME VIDEO
I don't know if it's even possible but it would be amazing.
Any thoughts or ideas?
Paul.
you could create a group/folder in super favourites , add all this e in your list to it , then set it as a main menu item.
Really? I had no idea! gonna take a deeper look at this! Thanks a lot!
BTW question is still open about adding more custom categories to the home Smile
@stunty999 , I increased the number of Custom Home items from 9 to 15 in the Leia version of the skin.
Regards,
Bart
Once again, you are a real MVP Bart!
Thank you so much for doing all this work in order to help us. Very very much appreciated Smile
Thread marked solved.
