Some Actors don't have pictures.
I think it's possible to edit a NFO, but where is the NFO to edit ? Do I have to create a new NFO ?
Thank you for your help.
You could edit the episode .nfo file for a movie or tv episode, and alter the actor tags, and re-import/rescrape it, but that's a lot of work.
xml:
<actor>
<name>Ramon De Ocampo</name>
<role></role>
<order>0</order>
<thumb>http://image.tmdb.org/t/p/original/ufbmBwY3P1dA8Cqxn28iZqes5rS.jpg</thumb>
</actor>
OK, thanks !
And do you know how I could remove actors from the actors list ? (some of them are useless)
(2018-08-23, 10:58)Groooompf Wrote: [ -> ](some of them are useless)
Such gratitude towards the actors... lol.
Simply remove them from the nfo file, delete the movie/show, and rescrape them locally.
(2018-08-23, 11:02)Klojum Wrote: [ -> ]Simply remove them from the nfo file, delete the movie/show, and rescrape them locally.
Not saying that this is wrong. But I would also check if the actor also was part in other movies/tv-shows. If so, you have to remove the actor from any NFO where he might be mentioned.
As said, it would be a lot of work. Also, some actors have minor (useless) roles in some movies, and perhaps play the main role in another movie. Do you delete him/her then as well? It's a per movie/tvshow decision.
