2018-08-27, 02:15
Hi All,
I am currently writing a bespoke controller to sit between openHab and Kodi as I found the Binding on offer very limited. The primary aim is to take voice command from Mycroft/Google Home/Alex and complete the actions I would normally use a remote for.
I have had a fair amount of success writing some php to handle most of what I want but I am looking for inspiration regarding handling searches. My ideal would be for Kodi to display the results of a search on screen, just if you had applied a filter to a Library window.
My backup will be to add them to a playlist and show the playlist.
Has any one done this or similar?
Full Source Code for my work so far.
Thanks in advance!
Thanks in advance!
