2018-08-27, 20:08
Hello,
I experience trouble playing a 4k (UHD) video on Kodi. The video stutter and when i check CPU usage it's almost 100%. The stutter only occurs when CPU reach 90 - 100%
However, if I open the same file on VLC (3.0), i have nearly no CPU usage and the video play correctly.
I've tried the following settings in KODI (fresh install) :
Allow hardware acceleration DXVA2 : OFF
Buffer : 2
Here is the log : http://paste.kodi.tv/butojudiwo
Let me know if you need more informations. I'm quite new to this, thank you in advance for your support.
Best Regards,
smh_ch
System spec :
CPU : I3 3.30 ghz
RAM : 4 gb
GFX : GTX 950
Buffer : 2
Best Regards,
smh_ch
System spec :
CPU : I3 3.30 ghz
RAM : 4 gb
GFX : GTX 950
