2018-08-31, 16:47
Hi Everyone,
This is my first post so go easy on me :p
I regularly browse through movies in my collection and would like to see the movie rating / score without having to go into info / extended info views for each and every movie. That way I can judge whether I want to watch a particular movie instantaneously.
The title, tag line and description is not enough information for me personally. Anyway, long story short, I decided to add this myself.
If anyone else would like this functionality, you can install as per the instructions below.
It's basically done by browsing into the Estuary skin's xml folder and replacing MyVideoNav.xml with the new version I've created.
The change modifies views with a left side panel i.e. List view and InfoWall views. An added bonus is that it can often work inside addons that display movies/videos also.
To install do this:
1. Navigate to the Kodi\addons\skin.estuary\xml\ directory (Location varies with platform).
2. Locate and rename the file MyVideoNav.xml and rename it e.g. MyVideoNav_old.xml
3. Download the new version from the link below and paste it into the same directory.
Note: Libreelec is a squash file system and therefore is read only. So this modification can only be installed in Libreelec via a workaround.
That's it!
Download Here
To install do this:
That's it!
Download Here
