Full Version: custom videoOSD.xml - modify default labels?
I control KODI through the HDMI-CEC option (panasonic tv remote), and  Long press down and UP does not work for audio and subtitle track. (I do not know why)
So I modified the default videoOSD.xml, to add shortcut directly - 4 shortcuts:  audioNextLanguage,CycleSubtitle, volampup (18x),volampdown(18x) (last two are for normalized shortcuts).
I have replaced the commands which I do not require.
However I did not found out (I'm completely new to kodi skin modify), how to replace the default description  (so as a temp. workaround, I just removed labels completely).
I would like to ask, If you  somebody has got some tips, how to add own labels to the modified buttons in the xml file.
Replaced text:
xml:
                    <control type="radiobutton" id="70011">
                        <include content="OSDButton">
                        <param name="texture" value="dialogs/volume/volume1.png"/>
                        </include>
                        <onclick>AudioNextLanguage</onclick>
                        </control>
                    <control type="radiobutton" id="70040">
                            <param name="texture" value="osd/fullscreen/buttons/settings-subtitle.png"/>
                        </include>
                        <onclick>CycleSubtitle</onclick>
                    </control>
                    <control type="radiobutton" id="70041">
                            <param name="texture" value="buttons/spinctrl/arrow-light-up.png"/>
                        </include>
                        <onclick>volampup</onclick>
                        <onclick>Dialog.Close(VideoOSD)</onclick>
                    </control>
                    <control type="radiobutton" id="700">
                        <param name="texture" value="buttons/spinctrl/arrow-light-down.png"/>
                        </include>
                        <onclick>volampdown</onclick>
                    </control>
the labels are added with
<control type="label">
     <top>0</top>
     <left>0</left>
     <width>0</width>
     <height>0</height>
     <aligny>center</aligny>
     <font>font30</font>
        <label></label>
         </control>
<label>volume</label>
         </control>
    </include>
    </control>
read home.xml
this may display it on the screen you will need to play with <top> and left
I have been able to add page title this way
https://forum.kodi.tv/showthread.php?tid=333279
I made workaround - used notification instead.  (works just fine for me)
example
    <control type="radiobutton" id="608">
                        </include>
                         <onfocus>Notification(DALSI TITULKY,.,500,osd/fullscreen/buttons/settings-subtitle.png)</onfocus>
                         <onunfocus></onunfocus>
                        <onclick>NextSubtitle</onclick>
                    </control>
