Full Version: 6 Channel Audio playback
Audio playback with 6 channel files seems messed up. Its not simply Stereo output I'm getting. E.g. front left comes out back right etc, half the channels area dead.
Audio Info within XMBC shows AC3 5.1 Channel correctly. Playing the same files in other players works fine.
Hardware is Turtlebeach. XMBC running default settings Installer_12282, also tested with fmpeg_cabac_win32_rev13073.zip update.
Video sample:
http://www.tfm.ro/ac3/_download.html
Anybody else having this problem?
PS: I see there is lots of open AC3 issues on the to-do list. I am just wondering if it should be working any better then it is... or if what I'm getting is completely normal with this build.
It is one the todo list but we need developers with test equipment.
Thanks for the info. I can post a more detailed report of what channels are flipped and not working later if that helps.
