2021-07-07, 10:15
(2021-07-06, 12:42)jim_p Wrote: [ -> ]Does anyone have a working installation of bello 7? I tried to install it yesterday on my tvbox that runs coreelec 9.2.7 (kodi 18.9).I just tried it on a fresh install of Libreelec 9.2.7 and it installs and runs fine. Maybe it didn't download all the dependencies if one failed? I would say there's something up with your environment rather than this skin.
At first, it failed to install some skin helper something addon (script.skin.helper.*). It got installed after 2 or 3 retries.
But when I loaded the skin, it showed an almost blank window with no menu in the middle and kodi did not react to any button presses. After a forced reboot, kodi failed to start many times and was crashing constanly, so all I could do is to wipe ~/.kodi completely and start fresh!
That being said wiping the whole .kodi directory is a bit extreme, you should just have to edit the guisettings.xml and change skin back to skin.default if you're having problems with the skin. Libreelec goes into safe mode after a number of failed boots as well.
