2018-09-07, 08:56
I have a shiny new remote control for Kodi. It comes with a built-in mouse, which I disable, but while the left-click button turns into the Enter key, the right-click button remains.
It is apparently very difficult to map a mouse button to an action in Kodi. In another thread, it is revealed that a keymap for <mouse><rightclick>…</rightclick></mouse> won't work, presumably because there is no mouse position when the mouse is disabled. My solution to this was to get Linux to map it to a key and then give that key an action in Kodi's keymap. (It would be nice if kodi could map mouse buttons as if they were keys without all of this extra work.)
There is some extra set-up to do first (please let me know if there's a better way do to this, this seems circuitous):
First, we need to create a new launcher that wraps around kodi. I use a kodi standalone session in lightdm, so for me that required editing /usr/share/xsessions/kodi.desktop to change kodi-standalone to kodi-standalone-plus and then create the following in /usr/local/bin/kodi-standalone-plus:
This checks for the presence of a ~/.kodi/plus/ directory (which you must create) and ensures you have the run-parts command. If you do, it then runs all executable scripts in that directory before starting the real kodi-standalone command. Make sure this new script is executable too: sudo chmod +x /usr/local/bin/kodi-standalone-plus
(It would be nice if Kodi had the above functionality built in, which might work better with its auto-restart loop for crash recovery.)
For the rest, you'll need to install xbindkeys and xautomation (for xte). In Ubuntu, that's just sudo apt-get install xbindkeys xautomation
Now that you can execute arbitrary scripts right before Kodi, let's create one, say ~/.kodi/plus/20_xbindkeys with content:
Okay. More checks for commands, a check to ensure there is a rc file, then we execute xbindkeys. Let's make that rc file:
This launches the shell command xte 'key XF86Back' which hits the Back key. It triggers on mouse button 3 (right click).
You can choose any key you like (consider any XF86 keyboard symbol for example) and then map it within Kodi as needed.
bash:#!/bin/sh
# kodi-standalone-plus by watch, https://forum.kodi.tv/showthread.php?tid=335312
# Run all executable scripts in ~/.kodi/plus (see `man run-parts`) then run kodi
if [ -d "$HOME/.kodi/plus" ] && command -v run-parts >/dev/null >&2; then
run-parts --report --exit-on-error "$HOME/.kodi/plus"
fi
kodi-standalone
bash:#!/bin/sh
RC="$HOME/.xbindkeysrc-kodi"
if command -v xbindkeys xte >/dev/null 2>&1 && [ -r "$RC" ]; then
xbindkeys -f "$RC" &
fi
bash:# Bind the right mouse button to "Back"
"xte 'key XF86Back'"
b:3
