I'm looking to create an XBMC screensaver. Is this possible without the XDK? I've downloaded TemplateXBS.rar, but it refers to xtl.h, which I can't find.
Is C++ a requirement for building a screensaver? It's been a long time since I've actually used C++.
You require the XDK if you want to build an xbox screensaver.
You can probably patch in to directx instead though until you get to the last points. I suspect some of the other screensavers have build options for directx.
You can use plain C if you wish - the dll interface has to export to C names at anyrate.
There's also tools/TestXBS that may be useful for you in SVN.
Cheers,
Jonathan
Too bad, I don't have the XDK, so there'd be no point in coding a screensaver I can't actually use
. I'll probably try to put something together using System.IdleTime(time) and see if I can kick off a python script from there.
Thanks for the confirmation, though.
I've read that the cpBlobs screensaver doesn't require the XDK, could that be right? It still does reference xtl.h
