Full Version: Kodi does not remember watched shows when streaming from FTP with tls
As the title says. Kodi is unable to remember watched shows when using FTP with tls authentication as a source. After watching an episode it gets marked as watched, but when you finish watching the next episode the checkmark on the previous episode is gone.
The error is present in both windows, android and ios version of kodi. (Tested with a clean install of Kodi 17.6).
It works fine over normal unencrypted FTP.
The source is added with the following string:  "ftp://username:[email protected]:port/?auth=tls"
If anyone could look into this it would be greatly appreciated.
(2018-09-09, 15:33)Oddi Wrote: [ -> ](Tested with a clean install of Kodi 17.6).
Double-check with a recent Kodi Leia Beta 2 (portable) installation, as v17.6 won't get any fixes anymore.
If the problem is still existent, please open a ticket at Kodi's bug tracker with full info/logs/etc.
