Full Version: fanart.tv: Peer certificate cannot be authenticated with given CA certificates
Using UMS and got a lot of following errors when scraping movie since yesterday. The movie information can be retrieved successfully, but no poster/fanart/discart can be downloaded automatically, manually choosing arts also doesn't work.
ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for https://assets.fanart.tv/fanart/movies/2...8cb3d1.png
ERROR: CCurlFile::Stat - Failed: Peer certificate cannot be authenticated with given CA certificates(60) for https://assets.fanart.tv/fanart/movies/2...93999f.png
ERROR: CCurlFile::Stat - Failed: Peer certificate cannot be authenticated with given CA certificates(60) for https://assets.fanart.tv/fanart/movies/2...e984ae.png
ERROR: CCurlFile::Stat - Failed: Peer certificate cannot be authenticated with given CA certificates(60) for https://assets.fanart.tv/fanart/movies/2...253567.jpg
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
Never mind, it seems to be the issue of fanart.tv and got fixed now.
Thread marked solved.
