Hello
I figured out how to change the custom widgets.
But I can not find the DVD Release/ Upcoming DVD widgets
it is like it is not installed somehow. I am not sure where this service is coming from.
I know it should be in the moviedb folder when I go through the widget navigation, but it seems maybe there was an error somewhere
I think there is something missing on my install or an error. So below I have shown the widget I can see from the custom menu.
This is from the extendedscripts menu
This is from the Moviedb within the extendedscripts folder where I think DVD options should be
Lastly this is the what I can see from the home page.
1. This is with the incoming/in theaters movies preset. Everything works
2. If I try to switch to DVD/ DVD Releases something breaks
Thanks for the very detailed description.
It seems you are doing everything correctly.
Make sure script.extendedinfo is installed (it probably is).
From the widget presets menu (where you see the widgets Movies, TV Shows, Add-ons, Games, New DVDs / Upcoming DVDs etc.), choose New DVDs / Upcoming DVDs.
Try restarting Kodi.
If you don't see the widget, the service from Rotten Tomatoes is probably down.
I'll try adding that widget myself later today.
I can't get that widget working either.
So maybe those API calls from Rotten Tomatoes are not working.
I did more research
For anyone else with this issue. I don't think it going to work
v5.6.0
- Fix support for Kodi L* nightlies
- Browser window improvements
- Fixes for TADB/LastFM
v5.5.3
- fixed non-workin search after it was cancelled earlier
- fix TheAudioDB listitem infolabels
- Cleanup
v5.5.2
- Added: runtime filter for movies & tvshows
- Added: "movie videos" listing for skins
- Adjusted Trakt stuff to use TMDB images (because of API changes)
- Removed: RottenTomatoes functionality (API is too shitty)
This is from the github. The version in 17.* and 18.* is 5.6 I believe. It seems like the feature was removed for all the rotten tomatoes calls. So that is why it was not working for me. Hopefully a replacement will come eventually. All the DVD release features use rotten tomatoes according to this.
https://github.com/forsomefun2/script.ex.../README.md
Ah, I see.
Thanks a lot for the info.
I'll remove that widget and replace it with something else either from script.extendedinfo or script.skin.helper.service.
I'm going to replace those widgets with "Top rated movies" and "Top rated tv shows".
What do you think?
