yup, getting the error now as well... all was working fine a few hours ago.
might be a temp issue.. they're currently not returning any UV data, which causes the crash
Hi .. hope its ok to join the discussion....
I have been using OZWEATHER and everything has been fine... temps and other details all display as designed.
But I would like to also have maps and radar .. so switched to WEATHERBIT
The maps etc all are fine but no temperates of other data .... and also not sure if the display is automatically updating..
I have uploadd a log file and here is a screen capture
https://1drv.ms/u/s!ArNrhN6XoXdQgY5f3bOGJoerGOgKMw
Any suggestions to get it all working ?
Cheers
Andrew
Weather error too, no data.
At the moment I get an Weatherbit IO error and I see this in my log. I've tried renaming and recreating the settings.xml file but still get the same error. I can see information in todays weather and the maps are present but no of the 10 day or hourly forecast information is populated
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: a float is required
File "C:\Users\Home User\AppData\Roaming\Kodi\addons\weather.weatherbit.io\default.py", line 474, in <module>
forecast(locationname, locationdeg)
File "C:\Users\Home User\AppData\Roaming\Kodi\addons\weather.weatherbit.io\default.py", line 250, in forecast
daily_props(daily_weather)
File "C:\Users\Home User\AppData\Roaming\Kodi\addons\weather.weatherbit.io\default.py", line 369, in daily_props
set_property('Daily.%i.UVIndex' % (count+1), str(int(round(item['uv']))) + '%')
TypeError: a float is required
this is my settings file with keys removed
-<settings version="2">
<setting id="API">xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</setting>
<setting id="Debug" default="true">false</setting>
<setting id="LatLon" default="true">false</setting>
<setting id="Location1">Liverpool (GB)</setting>
<setting id="Location1deg" default="true">['53.4084', '-2.99157']</setting>
<setting id="Location2" default="true"/>
<setting id="Location3" default="true"/>
<setting id="Location4" default="true"/>
<setting id="Location5" default="true"/>
<setting id="MAPAPI">xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</setting>
<setting id="WMaps">true</setting>
<setting id="Zoom">7</setting>
</settings>
Loaded but nothing seems to have changed
(2018-12-02, 14:40)Southernw2018 Wrote: [ -> ]Loaded but nothing seems to have changed
hmm.. i did test it with Hobart (AU) and seemed to work ok.
please provide a
Debug Log (see first post in this thread)
Hi Ronie ... I have posted the log file
Cheers
Andrew
(2018-12-03, 00:18)Southernw2018 Wrote: [ -> ]Hi Ronie ... I have posted the log file
Cheers
Andrew
great, but where can i find it?
paste.kodi.tv have I done it wrong ?
(2018-12-03, 03:10)Southernw2018 Wrote: [ -> ]paste.kodi.tv have I done it wrong ?
Yes. When you hit the Save button, you will see the screen refresh with your uploaded paste. You then copy the address in the address bar and paste it here. It will look something like this...
https://paste.kodi.tv/iminasanuq.kodi
There are thousands of logs there, and we will never find it.
