2019-03-09, 19:17
2019-03-09, 20:35
Figured it out. Deleted script.module.pil and the maps display.
2019-04-16, 19:05
error on libreelec latest with brussels set as location. tried using lat/long as someone posted above with the same error.
Quote:2019-04-16 19:01:51.498 T:3144004464 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: 'NoneType' object is not iterable
File "/storage/.kodi/addons/weather.weatherbit.io/default.py", line 495, in <module>
locationname, locationdeg = geoip()
TypeError: 'NoneType' object is not iterable
2019-04-26, 17:51
Great alternative to Yahoo!
Running Kodi 18.1 (Leia) with LibreELEC 9.0.1 (RPi2.arm) on RPi3 B+
Thanks roni (much appreciated).
2019-05-15, 21:01
(2019-04-16, 19:05)Ruckus Wrote: [ -> ]error on libreelec latest with brussels set as location. tried using lat/long as someone posted above with the same error.
same error with Nvidia SHIELD
thx for help!
2019-05-22, 22:57
(2018-09-11, 00:04)ronie Wrote: [ -> ]1 enable debug logging in kodi
2 enable logging in the weatherbit.io addon settings
3 restart kodi
4 go to the weather window
5 wait a few minutes
6 post the entire kodi.log file
Just installed from the repo, entered my API keys (weatherbit.io and openweathermap), but I only see a "BUSY" message and no weather data. The log seems that the script cannot connect. As requested, I completed steps 1-6. Link to debug log.
2019-05-23, 12:53
thx, looks like there's a problem connecting to both weatherbit.io and openweathermap.
makes me wonder, can kodi connect to the internet at all on your system?
2019-05-23, 20:59
(2019-05-23, 12:53)ronie Wrote: [ -> ]thx, looks like there's a problem connecting to both weatherbit.io and openweathermap.
Yes, I am able to use the youtube plugin and scrape content with Kodi scrapers. I can also see the IP of the box is successfully sending an DNS request to the following URLs when I view the weather plugin (pi-hole logs this):
* api.weatherbit.io
* weatherbit.io
* openweathermap.org
Is there any way to get more debug info from the scripts?
2019-05-25, 00:17
(2019-05-23, 20:59)graysky Wrote: [ -> ]Is there any way to get more debug info from the scripts?
i've added a bit of additional log info in these versions:
weather.weatherbit.io-0.0.17.zip
script.openweathermap.maps-0.2.4.zip
a possible cause for your issue could be incorrectly entered api keys...
2019-05-25, 12:43
2019-05-26, 12:53
in the last log, kodi isn't running the weather addon at all... for one reason or another..
can you double check weatherbit.io is still enabled and selected as the default weather addon?
2019-05-26, 15:02
If I nav to settings>add-ons>weather, "Weatherbit IO" has a check next to it. Then if I go to settings>services>weather, "none" was selected. That was the problem. It's working now. Has it always been the case that enabling a weather addon from add-ons did not set that in the services? In any case, thank you for the support and for this really great addon!
2019-06-03, 11:34
2019-07-13, 15:14
Hi ronie,
There is a copy/paste error in default.py in the method "def hourly_props(data)". Retrieving the value of the pod is incorrect. Instead of "pod = data['data'][0]['pod']", "pod = item['pod']" must be used.
Due to the error, the icons of daylight are used instead of those of the night.
2019-07-15, 01:53
Using latest OSMC, fully updated, I don't see any maps, or am unaware how to access them.
